Improved GSM-Based Localization by Incorporating Secondary Network Characteristics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marek Dvorsky
  • Fonction : Auteur
  • PersonId : 1009856
Libor Michalek
  • Fonction : Auteur
  • PersonId : 1009857
Pavel Moravec
  • Fonction : Auteur
  • PersonId : 1009858
Roman Sebesta
  • Fonction : Auteur
  • PersonId : 1009859
The techniques used in GSM networks for mobile station localization typically use several methods with different level of granularity, based on the base network parameters such as Cell Identification, Timing Advance, the position of Base Transceiver Station, the parameters of Base Transceiver Station antenna etc. This article introduces several others parameters that can be used for network description. This extension can be useful with visualization of localization outputs in cellular network.
Mots clés
978-3-642-30039-4_18_Chapter.pdf (109.76 Ko) Télécharger le fichier
hal-01533585 , version 1 (06-06-2017)
Paternité
Marek Dvorsky, Libor Michalek, Pavel Moravec, Roman Sebesta. Improved GSM-Based Localization by Incorporating Secondary Network Characteristics. Networking Workshops (NETWORKING), May 2012, Prague, Czech Republic. pp.139-144, ⟨10.1007/978-3-642-30039-4_18⟩. ⟨hal-01533585⟩
63 Consultations
121 Téléchargements
