Comparison of initial partitioning methods for multilevel direct k-way graph partitioning with fixed vertices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 2017
In scientific computing, load balancing is a crucial step conditioning the performance of large-scale applications. In this case, an efficient decomposition of the workload to a number of processors is highly necessary. A common approach to solve this problem is to use graph representation and perform a graph partitioning in k parts using the multilevel framework and the recursive bisection (RB) paradigm. However, in graph instances where fixed vertices are used to model additional constraints, RB often produces partitions of poor quality.In this paper, we investigate the difficulties of RB to handle fixed vertices and we compare its results with two different alternatives. The first one, called KGGGP is a direct k-way greedy graph growing partitioning that properly handles fixed vertices while the second one, introduced in kPaToH, uses RB and a post-processing technique to correct the obtained partition. Finally, experimental results on graphs that represent real-life numerical simulations show that both alternative methods provide improved partitions compared to RB.
parco16.pdf (1.08 Mo) Télécharger le fichier
hal-01538600 , version 1 (14-06-2017)
Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
Maria Predari, Aurélien Esnard, Jean Roman. Comparison of initial partitioning methods for multilevel direct k-way graph partitioning with fixed vertices. Parallel Computing, 2017, ⟨10.1016/j.parco.2017.05.002⟩. ⟨hal-01538600⟩
Collections
CNRS INRIA INRIA2
347 Consultations
729 Téléchargements
