No Tradeoff between Confidentiality and Performance: An Analysis on H.264/SVC Partial Encryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zhuo Wei
  • Fonction : Auteur
  • PersonId : 1010438
Xuhua Ding
  • Fonction : Auteur
  • PersonId : 1010439
Robert Huijie Deng
  • Fonction : Auteur
  • PersonId : 1010440
Partial encryption is often used as a tradeoff between security and performance to protect scalable video data. In this paper, we argue that although partial encryption is strong enough for access control, it is not adequate for content confidentiality protection. We conduct experiments to show that partially encrypted H.264/SVC (scalable video coding) streams leak significant content information from the enhancement layers in all three scalability dimensions. Our analysis concludes that such leakage is caused by the underlying coding techniques used in H.264/SVC, and all layers should be encrypted to protect confidential video streams.
978-3-642-32805-3_6_Chapter.pdf (2.53 Mo) Télécharger le fichier
hal-01540901 , version 1 (16-06-2017)
Paternité
Zhuo Wei, Xuhua Ding, Robert Huijie Deng, Yongdong Wu. No Tradeoff between Confidentiality and Performance: An Analysis on H.264/SVC Partial Encryption. 13th International Conference on Communications and Multimedia Security (CMS), Sep 2012, Canterbury, United Kingdom. pp.72-86, ⟨10.1007/978-3-642-32805-3_6⟩. ⟨hal-01540901⟩
49 Consultations
64 Téléchargements
