A Framework for Security Context Migration in a Firewall Secured Virtual Machine Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zahra Tavakoli
  • Fonction : Auteur
  • PersonId : 1010670
Sebastian Meier
  • Fonction : Auteur
  • PersonId : 1010671
Alexander Vensmer
  • Fonction : Auteur
  • PersonId : 1010672
Current virtualization technologies enable hosting of a large number of Virtual Machines (VMs) on a common physical host. The hypervisor interconnects these VMs via Virtual Networks (VNs). These VNs underlie the same security requirements as physical networks. Network elements such as stateful firewalls contribute in enforcing this security. With the advent of stateful firewalls on the hypervisor level, a new challenge arises when it comes to VM migration. Not only the VM itself, but also the associated Security Context (SC) has to migrate. Current open-source hypervisors do not address this issue. In this paper we present the architecture and implementation of our framework for migrating SC along with VMs.
978-3-642-32808-4_5_Chapter.pdf (1.63 Mo) Télécharger le fichier
hal-01543146 , version 1 (20-06-2017)
Paternité
Zahra Tavakoli, Sebastian Meier, Alexander Vensmer. A Framework for Security Context Migration in a Firewall Secured Virtual Machine Environment. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.41-51, ⟨10.1007/978-3-642-32808-4_5⟩. ⟨hal-01543146⟩
93 Consultations
190 Téléchargements
