Receiver-Initiated vs. Short-Preamble Burst MAC Approaches for Multi-channel Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cristina Cano
  • Fonction : Auteur
  • PersonId : 1010679
Boris Bellalta
  • Fonction : Auteur
  • PersonId : 1010680
Miquel Oliver
  • Fonction : Auteur
  • PersonId : 1010681
Wireless Sensor Networks (WSNs) are networks formed by highly constrained devices that communicate measured environmental data using low-power wireless transmissions. The increase of spectrum utilization in non-licensed bands along with the reduced power used by these nodes is expected to cause high interference problems in WSNs. Therefore, the design of new dynamic spectrum access techniques specifically tailored to these networks plays an important role for their future development. This work aims to provide insights into the performance of two well-known low energy-consuming Medium Access Control (MAC) techniques for WSNs (the receiver-initiated and the short-preamble burst), adapted to work with multiple channels. The results obtained show the best working conditions for each approach.
978-3-642-32808-4_3_Chapter.pdf (117.49 Ko) Télécharger le fichier
hal-01543153 , version 1 (20-06-2017)
Paternité
Cristina Cano, Boris Bellalta, Miquel Oliver. Receiver-Initiated vs. Short-Preamble Burst MAC Approaches for Multi-channel Wireless Sensor Networks. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.23-32, ⟨10.1007/978-3-642-32808-4_3⟩. ⟨hal-01543153⟩
41 Consultations
113 Téléchargements
