Radio Propagation Modeling on 433 MHz - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In wireless network design and positioning it is essential to use radio propagation models for the applied frequency and environment. There are many propagation models available for both indoor and outdoor environments; however, they are not applicable for 433 MHz ISM frequency, which is perfectly suitable for smart metering and sensor networking applications.During our work, we gathered the most common propagation models available in scientific literature, broke them down to components and analyzed their behavior. Based on our research and measurements, a method was developed to create a propagation model for both indoor and outdoor environment optimized for 433 MHz frequency.The possible application areas of the proposed models: smart metering, sensor networks, positioning.
978-3-642-32808-4_35_Chapter.pdf (3.48 Mo) Télécharger le fichier
hal-01543157 , version 1 (20-06-2017)
Paternité
Ákos Milánkovich, Károly Lendvai, Sándor Imre, Sándor Szabó. Radio Propagation Modeling on 433 MHz. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.384-395, ⟨10.1007/978-3-642-32808-4_35⟩. ⟨hal-01543157⟩
64 Consultations
1112 Téléchargements
