White Spaces in UHF Band: Catalonia Case Study and Impact of the Digital Dividend - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Albert Domingo
  • Fonction : Auteur
  • PersonId : 1010704
Boris Bellalta
  • Fonction : Auteur
  • PersonId : 1010680
Miquel Oliver
  • Fonction : Auteur
  • PersonId : 1010681
White Spaces in the UHF bands are very interesting because of their potential use in rural communications, but their feasibility needs to be proven. This paper analyses the TV spectrum occupation in the region of Catalonia, Spain, because it will be one of the first EU regions where changes in the UHF band are going to be implemented. Those changes are derived from the implementation of the Digital Dividend. The goal of this paper is to correlate population density with future free channel availability, and to proof that communications through TV White Spaces equipment is a good candidate for low density population areas.
978-3-642-32808-4_4_Chapter.pdf (232.95 Ko) Télécharger le fichier
hal-01543168 , version 1 (20-06-2017)
Paternité
Albert Domingo, Boris Bellalta, Miquel Oliver. White Spaces in UHF Band: Catalonia Case Study and Impact of the Digital Dividend. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.33-40, ⟨10.1007/978-3-642-32808-4_4⟩. ⟨hal-01543168⟩
66 Consultations
263 Téléchargements
