Finding Typical Internet User Behaviors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In various network tests we often need to use different trace files in order to get the most comprehensive result. This procedure requires multiple input files which were generated in different ways. In this paper we suggest a method for analyzing a traffic measurement and extracting the most typical user behaviors. We introduce the Traffic Descriptive Strings (TDS) which is a projection of measurement data. We present an algorithm which is able to score the similarities between two TDSs.
978-3-642-32808-4_29_Chapter.pdf (110.1 Ko) Télécharger le fichier
hal-01543170 , version 1 (20-06-2017)
Paternité
Péter Megyesi, Sándor Molnár. Finding Typical Internet User Behaviors. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.321-327, ⟨10.1007/978-3-642-32808-4_29⟩. ⟨hal-01543170⟩
217 Consultations
71 Téléchargements
