Comparison of damage localization in mechanical systems based on Stochastic Subspace Identification method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2017
Damage identification in mechanical systems under vibration excitation relates to the monitoring of the changes in the dynamical properties of the corresponding linear system, and thus reflects changes in modal parameters (frequencies, damping, mode shapes) and finally in the finite element model of the structure. Damage localization can be performed using ambient vibration data collected from sensors in the reference and possibly damaged state and information from a finite element model (FEM). Two approaches are considered in this framework, the Stochastic Dynamic Damage Location Vector (SDDLV) approach and the Subspace Fitting (SF) approach. Both localization algorithms are presented and their performance is illustrated and compared on simulated and experimental vibration data.
EGUPosterModif.pdf (408.97 Ko) Télécharger le fichier
hal-01545346 , version 1 (22-06-2017)
  • HAL Id : hal-01545346 , version 1
Guillaume Gautier, Md Delwar Hossain Bhuyan, Michael Döhler, Laurent Mevel. Comparison of damage localization in mechanical systems based on Stochastic Subspace Identification method. EGU General Assembly, Apr 2017, Vienna, Austria. 2017. ⟨hal-01545346⟩
336 Consultations
75 Téléchargements
