Algorithms Based on Finite Automata for Testing of Z-codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose an algorithm to decide whether a regular language recognized by finite automata is a Z-code or not. This algorithm has time complexity O(n4) for the general case of non-deterministic automata, O(n2) for the restricted case of deterministic automata, where n is the number of states of finite automata.
978-3-642-35606-3_74_Chapter.pdf (324.77 Ko) Télécharger le fichier
hal-01551321 , version 1 (30-06-2017)
Paternité
Dang Quyet Thang, Nguyen Dinh Han, Phan Trung Huy. Algorithms Based on Finite Automata for Testing of Z-codes. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.625-635, ⟨10.1007/978-3-642-35606-3_74⟩. ⟨hal-01551321⟩
51 Consultations
57 Téléchargements
