UKCF: A New Graphics Driver Cross-Platform Translation Framework for Virtual Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Virtual machine with dynamic binary translation system is the key technology to solve software compatibility problem. But traditional user space binary translation systems can’t translate hardware drivers such as graphics drivers in operating system kernel directly, instead, they need translate the entire operating system. To solve this problem, we designed a new binary translation framework. This framework has a user space translator and a kernel space translator working coordinated and can translate graphics drivers directly. Compared with traditional binary translation systems, this framework can significantly improve the performance of the virtual machine. Based on our experiment, the multimedia performance of virtual machines can been improved about 30%.
978-3-642-35606-3_18_Chapter.pdf (305.19 Ko) Télécharger le fichier
hal-01551325 , version 1 (30-06-2017)
Paternité
Haitao Jiang, Yun Xu, Yin Liao, Guojie Jin, Guoliang Chen. UKCF: A New Graphics Driver Cross-Platform Translation Framework for Virtual Machines. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.156-163, ⟨10.1007/978-3-642-35606-3_18⟩. ⟨hal-01551325⟩
56 Consultations
77 Téléchargements
