Relationship between Correcting Code and Module Technique in Hiding Secret Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Phan Trung Huy
  • Fonction : Auteur
  • PersonId : 1011206
Nguyen Hai Thanh
  • Fonction : Auteur
  • PersonId : 1011331
Cheonsick Kim
  • Fonction : Auteur
  • PersonId : 1011185
In this paper, we show the role of modules over rings of finite characteristics in data hiding area. Applications of correcting codes and covering functions in data hiding are shown as special cases of our module approach. Applications of modules over rings of characteristic 2 to design new embedding schemes for hiding secret data in binary images are introduced.
978-3-642-35606-3_35_Chapter.pdf (225.39 Ko) Télécharger le fichier
hal-01551381 , version 1 (30-06-2017)
Paternité
Phan Trung Huy, Nguyen Hai Thanh, Cheonsick Kim. Relationship between Correcting Code and Module Technique in Hiding Secret Data. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.297-307, ⟨10.1007/978-3-642-35606-3_35⟩. ⟨hal-01551381⟩
37 Consultations
71 Téléchargements
