A novel fast Fourier transform accelerated off-grid exhaustive search method for cryo-electron microscopy fitting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Crystallography Année : 2017
This paper presents a novel fast Fourier transform (FFT)-based exhaustive search method extended to off-grid translational and rotational degrees of freedom. The method combines the advantages of the FFT-based exhaustive search, which samples all the conformations of a system under study on a grid, with a local optimization technique that guarantees to find the nearest optimal off-grid conformation. The method is demonstrated on a fitting problem and can be readily applied to a docking problem. The algorithm first samples a scoring function on a six-dimensional grid of size N6 using the FFT. This operation has an asymptotic complexity of O(N6logN). Then, the method performs the off-grid search using a local quadratic approximation of the cost function and the trust-region optimization algorithm. The computation of the quadratic approximation is also accelerated by FFT at the same additional asymptotic cost of O(N6logN). The method is demonstrated by fitting atomic protein models into several simulated and experimental maps from cryo-electron microscopy. The method is available at https://team.inria.fr/nano-d/software/offgridfit.
2017-Hoffmann-preprint-A novel fast Fourier transform accelerated off-grid exhaustive search method for cryo-electron microscopy fitting.pdf (1.88 Mo) Télécharger le fichier
hal-01553293 , version 1 (01-08-2017)
Copyright (Tous droits réservés)
Alexandre Hoffmann, Valérie Perrier, Sergei Grudinin. A novel fast Fourier transform accelerated off-grid exhaustive search method for cryo-electron microscopy fitting. Journal of Applied Crystallography, 2017, 50 (4), pp.1036-1047. ⟨10.1107/S1600576717008172⟩. ⟨hal-01553293⟩
447 Consultations
404 Téléchargements
