Brain-Computer Interface Games: Towards a Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hayrettin Gürkök
  • Fonction : Auteur
  • PersonId : 1011707
Mannes Poel
  • Fonction : Auteur
  • PersonId : 1011708
The brain-computer interface (BCI) community started to consider games as potential applications while the games community started to consider BCI as a game controller. However, there is a discrepancy between the BCI games developed by the two communities. In this paper, we propose a preliminary BCI games framework that we constructed with respect to the research conducted in both the BCI and the games communities. Developers can situate their BCI games within this framework and benefit from the guidelines we provide and also extend the framework further.
978-3-642-33542-6_33_Chapter.pdf (63.96 Ko) Télécharger le fichier
hal-01556145 , version 1 (04-07-2017)
Paternité
Hayrettin Gürkök, Anton Nijholt, Mannes Poel. Brain-Computer Interface Games: Towards a Framework. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.373-380, ⟨10.1007/978-3-642-33542-6_33⟩. ⟨hal-01556145⟩
51 Consultations
370 Téléchargements
