The Effectiveness and Efficiency of Model Driven Game Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order for techniques from Model Driven Engineering to be accepted at large by the game industry, it is critical that the effectiveness and efficiency of these techniques are proven for game development. There is no lack of game design models, but there is no model that has surfaced as an industry standard. Game designers are often reluctant to work with models: they argue these models do not help them design games and actually restrict their creativity. At the same time, the flexibility that model driven engineering allows seems a good fit for the fluidity of the game design process, while clearly defined, generic models can be used to develop automated design tools that increase the development’s efficiency.
978-3-642-33542-6_71_Chapter.pdf (129.74 Ko) Télécharger le fichier
hal-01556176 , version 1 (04-07-2017)
Paternité
Joris Dormans. The Effectiveness and Efficiency of Model Driven Game Design. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.542-548, ⟨10.1007/978-3-642-33542-6_71⟩. ⟨hal-01556176⟩
48 Consultations
122 Téléchargements
