Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : The present paper focus on the computer programming for a beginning level of learning. Students´ learning challenges were identified through literature review. We propose a solution that enables students to interact with an editor that gives an output as a response. We also analyze the impact of the use of this framework and identify that some support tools. Preliminary evaluation shows that some of the support tools are more effective than others.
https://hal.inria.fr/hal-01556178 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, July 4, 2017 - 5:03:06 PM Last modification on : Tuesday, June 29, 2021 - 12:20:08 PM Long-term archiving on: : Friday, December 15, 2017 - 2:45:49 AM
Carlos J. Costa, Manuela Aparicio, Carlos Cordeiro. Web-Based Graphic Environment to Support Programming in the Beginning Learning Process. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.413-416, ⟨10.1007/978-3-642-33542-6_41⟩. ⟨hal-01556178⟩
