Agricultural Environmental Information Collection Device Based on Raspberry Pi
Integrated agricultural environmental information real-time collection, transmission and management is extremely critical for precision agriculture (PA). This paper describes the basic knowledge and primary principles used in an agricultural environmental information collection device. The device is based on Raspberry Pi, combining with GPS module, some digital sensors and analog sensors to measure environmental temperature and humidity, barometric pressure, light intensity, soil moisture and other environmental information accurate collection. All collected data was real-time transmitted to a remote server specified database for management. In the experiment process, the device has been proved to have the ability to catch the distributed information and also can get different centralized data management. The results show the integration of operational information collection, transmission and management, as well as the use of open source software to make it easy to collect multiple types of data parallelism, which provides an important solution for the rapid transformation of agricultural production.
Informatique [cs]
