Equivalences for Free! - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Homotopy Type Theory promises a unification of the concepts of equality and equivalence in Type Theory, through the introduction of the univalence principle. However, existing proof assistants based on type theory treat this principle as an axiom, and it is not yet entirely clear how to extend them to handle univalence internally. In this paper, we propose a construction grounded on a univalent version of parametricity to bring the benefits of univalence to the programmer and prover, that can be used on top of existing type theories. In particular, univalent parametricity strengthens parametricity to ensure preservation of type equivalences. We present a lightweight framework implemented in the Coq proof assistant that allows the user to transparently transfer definitions and theorems for a type to an equivalent one, as if they were equal. We study and strive to maximize the effectiveness of these transports in terms of computational behavior, relying on the univalence axiom as little as possible. Our approach handles both type and term dependency.
main.pdf (779.31 Ko) Télécharger le fichier
hal-01559073 , version 1 (11-07-2017)
hal-01559073 , version 2 (25-07-2017)
hal-01559073 , version 3 (21-03-2018)
hal-01559073 , version 4 (16-07-2018)
hal-01559073 , version 5 (17-07-2018)
hal-01559073 , version 6 (14-10-2019)
  • HAL Id : hal-01559073 , version 1
Nicolas Tabareau, Éric Tanter, Matthieu Sozeau. Equivalences for Free!: Univalent Parametricity for Effective Transport. 2017. ⟨hal-01559073v1⟩
2227 Consultations
1336 Téléchargements
