Application of Background Information Database in Drought Monitoring of Guangxi in 2010 - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
In this paper, use Nanning city as an example to show application of Background information database in drought monitoring. A near-real time drought monitoring approach is developed using Terra-Moderate Resolution Imaging Spectoradiometer (MODIS) Normalized Difference Vegetation Index (NDVI) and Land Surface Temperature (LST) products. The approach is called Vegetation Temperature Condition Index (VTCI), which integrates land surface reflectance and thermal properties. VTCI is defined as the ratio of LST differences among pixels with a specific NDVI value in a sufficiently large study area; The ground-measured precipitation data from a study area covering Nanning in Guangxi , CHINA, are used to validate the drought monitoring approach. Taking the result of drought monitoring in background information of Nanning city ,the area of farmland drought of Mild drought Moderate droughts Severe drought were 223607.2 Ha ,310596.9 Ha and 513.2 Ha.
978-3-642-18333-1_32_Chapter.pdf (325 Ko) Télécharger le fichier
Dates and versions
hal-01559551 , version 1 (10-07-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Xin Yang, Weiping Lu, Chaohui Wu, Yuhong Li, Shiquan Zhong. Application of Background Information Database in Drought Monitoring of Guangxi in 2010. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.275-281, ⟨10.1007/978-3-642-18333-1_32⟩. ⟨hal-01559551⟩
33 View
59 Download
Share
