Design of Greenhouse Environmental Parameters Prediction System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper designs an environmental parameters prediction system based on web for greenhouse. The system is designed using the MVC framework, and includes monitoring module and prediction module. The system can obtain the main environmental parameters from sensors, such as light, temperature, humidity, CO2 and so on. Based on mass and energy balance principle, the prediction module of the system can predict the parameters of the greenhouse environment each day. The system displays the measured real-time data and the predicted data for the users to manage greenhouse easily. This paper provides a specific method to realize an intelligent management system for greenhouse.
978-3-642-18333-1_59_Chapter.pdf (133.88 Ko) Télécharger le fichier
hal-01559575 , version 1 (10-07-2017)
Paternité
Haokun Zhang, Heru Xue. Design of Greenhouse Environmental Parameters Prediction System. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.502-507, ⟨10.1007/978-3-642-18333-1_59⟩. ⟨hal-01559575⟩
64 Consultations
80 Téléchargements
