A System for Detection and Recognition of Pests in Stored-Grain Based on Video Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ying Yang
  • Fonction : Auteur
  • PersonId : 1012406
Bo Peng
  • Fonction : Auteur
  • PersonId : 972265
Jianqin Wang
  • Fonction : Auteur
  • PersonId : 986515
This paper presents a system for detection and recognition of pests in stored-grain based on video analysis. Unlike current systems which conduct analysis of static images, the proposed system uses video data captured by camera and performs video analysis to detect and recognize pests in grain. By using video data instead of static images, techniques such as motion estimation and multiple-frame verification are used to locate, count and recognize pests. Compared to systems based on image processing, the proposed system is more robust to moving pests and avoids missing and re-counting of moving pests. Furthermore, by analyzing motion of pests in video, the system can only count living pests and ignore dead ones, which are recommended by national standard of grain quality and cannot be achieved by current systems based on static image processing.
978-3-642-18333-1_16_Chapter.pdf (132.23 Ko) Télécharger le fichier
hal-01559588 , version 1 (10-07-2017)
Paternité
Ying Yang, Bo Peng, Jianqin Wang. A System for Detection and Recognition of Pests in Stored-Grain Based on Video Analysis. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.119-124, ⟨10.1007/978-3-642-18333-1_16⟩. ⟨hal-01559588⟩
84 Consultations
142 Téléchargements
