Evaluation on the Agricultural Website’s Efficiency Based on DEA Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shangmin Deng
  • Fonction : Auteur
  • PersonId : 1012410
Weili Men
  • Fonction : Auteur
  • PersonId : 1012411
An information-driven agriculture is firstly agriculture digitalization, the foundation of which is the construction of agricultural information networks. Based on the methods of website evaluation, an indicator system of efficiency evaluation for agricultural information websites is constructed in this thesis. Then the efficiency of 17 municipal websites in Shandong province are analyzed by the C2R Model in DEA. The result declares that 3 of these websites are related effective and the other 14 are non-effective. By an analysis of projection, this thesis also gives suggestions to improve the performance of the non-effective.
978-3-642-18333-1_81_Chapter.pdf (164.26 Ko) Télécharger le fichier
hal-01559594 , version 1 (10-07-2017)
Paternité
Shangmin Deng, Weili Men. Evaluation on the Agricultural Website’s Efficiency Based on DEA Method. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.674-680, ⟨10.1007/978-3-642-18333-1_81⟩. ⟨hal-01559594⟩
36 Consultations
83 Téléchargements
