Design and Simulation of Jujube Sapling Transplanter
This paper is aiming at designing a novel jujube transplanter with mechanic arms, which can support the sapling for a while when other operations is going on. It improves uniformity and stability. Pro-E software has been used for the design process, by which transplanting process has been analyzed and simulated.
