A new route for semi-solid steel forging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue CIRP Annals - Manufacturing Technology Année : 2017
Forging in semi-solid state significantly extends the possibilities of classical hot forging. In order to fully exploit its potential, the process requires a specific and demanding environment, penalizing its industrial deployment. In this context, an alternative route is proposed. In the proposed process, semi-solid zones at the heart of the material coexist with surrounding solid zones within the part. The outcome is an optimized process where the benefits of thixoforging are reached at a significant extent within the classical process framework of hot forging. The paper investigates this proposal up to a full-scale proof-of concept in an industrial setting.
Mots clés
CIRP paper - Balan, Becker, Langlois, Bigot - forSAM.pdf (1.43 Mo) Télécharger le fichier
hal-01560824 , version 1 (12-07-2017)
Tudor Balan, Eric Becker, Laurent Langlois, Régis Bigot. A new route for semi-solid steel forging. CIRP Annals - Manufacturing Technology, 2017, 66 (1), pp.297-300. ⟨10.1016/j.cirp.2017.04.111⟩. ⟨hal-01560824⟩
86 Consultations
189 Téléchargements
