New interface
Preprints, Working Papers, ...
Towards Hardware IIR Filters Computing Just Right: Direct Form I Case Study
Anastasia Volkova 1 Matei Istoan 2 Florent de Dinechin 2 Thibault Hilaire 1, 3
1 PEQUAN - Performance et Qualité des Algorithmes Numériques
LIP6 - Laboratoire d'Informatique de Paris 6
2 SOCRATE - Software and Cognitive radio for telecommunications
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
3 TOCCATA - Formally Verified Programs, Certified Tools and Numerical Computations
LRI - Laboratoire de Recherche en Informatique, Inria Saclay - Ile de France
Abstract : Linear Time Invariant (LTI) filters are often specified and simulated using high-precision software, before being implemented in low-precision hardware. A problem is that the hardware does not behave exactly as the simulation due to quantization and rounding issues. This article advocates the construction of LTI architectures that behave as if the computation was performed with infinite accuracy, then rounded only once to the low-precision output format. From this minimalist specification, it is possible to deduce the optimal values of many architectural parameters, including all the internal data formats. This requires a detailed error analysis that captures the rounding errors, but also their infinite accumulation in infinite impulse response filters. This error analysis then guides the design of hardware satisfying the accuracy specification at the minimal hardware cost. This is illustrated on the case of low-precision LTI filters implemented in FPGA logic. This approach is fully automated in a generic, open-source architecture generator tool built upon the FloPoCo framework, and evaluated on a range of Finite and Infinite Impulse Response filters.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.sorbonne-universite.fr/hal-01561052
Contributor : Anastasia Volkova Connect in order to contact the contributor
Submitted on : Friday, December 15, 2017 - 4:58:23 PM
Last modification on : Friday, January 8, 2021 - 5:40:03 PM
File
LTICJR.pdf
Identifiers
  • HAL Id : hal-01561052, version 2
Collections
Citation
Anastasia Volkova, Matei Istoan, Florent de Dinechin, Thibault Hilaire. Towards Hardware IIR Filters Computing Just Right: Direct Form I Case Study. {date}. ⟨hal-01561052v2⟩
Share
Metrics
Record views
1360
Files downloads
878
