Spatio-Temporal dMRI Acquisition Design: Reducing the Number of $q\tau$ Samples Through a Relaxed Probabilistic Model
Acquisition time is a major limitation in recovering brain white matter microstructure with diffusion Magnetic Resonance Imaging. Finding a sampling scheme that maximizes signal quality and satisfies given time constraints is NP-hard. We alleviate that by introducing a relaxed probabilistic model of the problem, for which sub-optimal solutions can be found effectively. Our model is defined in the $q\tau$ space, so that it captures both spacial and temporal phenomena. The experiments on synthetic data and in-vivo diffusion images of the C57Bl6 wild-type mice reveal superiority of our technique over random sampling and even distribution in the $q\tau$ space.
main.pdf (821.78 Ko)
Télécharger le fichier
aliascnt.sty (2.54 Ko)
llncs.cls (41.9 Ko)
llncsdoc.sty (1.45 Ko)
main.aux (7.17 Ko)
main.bbl (5 Ko)
rat_body_msd.pdf (17.15 Ko)
rat_body_rtap.pdf (16.4 Ko)
rat_body_rtop.pdf (17.18 Ko)
rat_body_rtpp.pdf (17.26 Ko)
rat_genu_msd.pdf (17.15 Ko)
rat_genu_rtap.pdf (16.4 Ko)
rat_genu_rtop.pdf (17.19 Ko)
rat_genu_rtpp.pdf (17.25 Ko)
rat_splenium_msd.pdf (17.13 Ko)
rat_splenium_rtap.pdf (16.4 Ko)
rat_splenium_rtop.pdf (17.18 Ko)
rat_splenium_rtpp.pdf (17.25 Ko)
references.bib (7.98 Ko)
remreset.sty (1.07 Ko)
signed_consent_form.pdf (6.88 Mo)
splncs.bst (20.03 Ko)
splncs03.bst (32.32 Ko)
splncs_srt.bst (22.79 Ko)
sprmindx.sty (82 B)
watson_noiseless_msd.pdf (18.6 Ko)
watson_noiseless_rtap.pdf (17.39 Ko)
watson_noiseless_rtop.pdf (17.13 Ko)
watson_noiseless_rtpp.pdf (17.1 Ko)
watson_snr10_msd.pdf (18.79 Ko)
watson_snr10_rtap.pdf (17.57 Ko)
watson_snr10_rtop.pdf (17.26 Ko)
watson_snr10_rtpp.pdf (17.27 Ko)
watson_snr20_msd.pdf (18.78 Ko)
watson_snr20_rtap.pdf (17.55 Ko)
watson_snr20_rtop.pdf (17.28 Ko)
watson_snr20_rtpp.pdf (17.26 Ko)
watson_snr20_scheme_1.pdf (50.88 Ko)
watson_snr20_scheme_2.pdf (57.51 Ko)
watson_snr20_scheme_3.pdf (63.07 Ko)
