Measurement of Chili Pepper Plants Size Based on Mathematical Morphology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Since chili pepper plant size directly reflects the state of plant growth, a method for pepper measurement of plants size was discussed here. Pepper plants were shot from above once per week in the greenhouse since being field planted in spring. The method of processing the pepper plant images was studied, in which the image segmentation of combination of color space and the image morphological operations were applied. And the major axis and minor axis of pepper plant, for describing the size of the plant, were calculated from single connected component in the image being processed. According to the method, a program for pepper plant size measurement based on MATLAB was developed. Experimental results have demonstrated that the method is more reasonable and accurate than artificial measure.
978-3-642-18336-2_8_Chapter.pdf (393.2 Ko) Télécharger le fichier
hal-01562720 , version 1 (17-07-2017)
Paternité
Yun Gao, Xiaoyu Li, Kun Qi, Hong Chen. Measurement of Chili Pepper Plants Size Based on Mathematical Morphology. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.61-70, ⟨10.1007/978-3-642-18336-2_8⟩. ⟨hal-01562720⟩
70 Consultations
84 Téléchargements
