Simulation Study of a Novel Algorithm for Digital Relaying Based on FPGA
The paper proposes a new fast Fourier transform (FFT) protection algorithm for digital relaying based on field-programmable gate array (FPGA), constructs detailed models and performs corresponding simulations. Simulation results show that the harmonic components of voltages and currents can be conveniently calculated, and the digital protection functions can be effectively fulfilled with enhanced accuracy and reduced storage requirements.
Informatique [cs]
