A Deductive View on Process-Data Diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Manfred A. Jeusfeld
  • Fonction : Auteur
  • PersonId : 1012787
Process-Data Diagrams (PDDs) are a popular technique to represent method fragments and their recombination to new adapted method specifications. It turns out that PDDs are at odds with a strict separation of MOF/MDA abstraction levels as advocated by MOF/MDA. We abandon the restriction and specify PDDs by a metametamodel that supports both process and product parts of PDDs. The instantiation of the process side of PDDs can then the used as the type level for a simple traceability framework. The deductive formalization of PDDs allows to augment them by a plethora of analysis tools. The recombination of method fragments is propagated downwards to the recombination of the process start and end points. The hierarchical structure of the product side of PDDs can be used to detect unstructured updates from the process side.
978-3-642-19997-4_13_Chapter.pdf (388.42 Ko) Télécharger le fichier
hal-01562877 , version 1 (17-07-2017)
Paternité
Manfred A. Jeusfeld. A Deductive View on Process-Data Diagrams. 4th Working Conference on Method Engineering (ME), Apr 2011, Lisbon, Portugal. pp.123-137, ⟨10.1007/978-3-642-19997-4_13⟩. ⟨hal-01562877⟩
150 Consultations
59 Téléchargements
