PAC-Bayes and Domain Adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Pascal Germain
Amaury Habrard
Emilie Morvant
We provide two main contributions in PAC-Bayesian theory for domain adaptation where the objective is to learn, from a source distribution, a well-performing majority vote on a different, but related, target distribution. Firstly, we propose an improvement of the previous approach we proposed in Germain et al. (2013), which relies on a novel distribution pseudodistance based on a disagreement averaging, allowing us to derive a new tighter domain adaptation bound for the target risk. While this bound stands in the spirit of common domain adaptation works, we derive a second bound (recently introduced in Germain et al., 2016) that brings a new perspective on domain adaptation by deriving an upper bound on the target risk where the distributions' divergence—expressed as a ratio—controls the trade-off between a source error measure and the target voters' disagreement. We discuss and compare both results, from which we obtain PAC-Bayesian generalization bounds. Furthermore, from the PAC-Bayesian specialization to linear classifiers, we infer two learning algorithms, and we evaluate them on real data.
main.pdf (1.54 Mo) Télécharger le fichier
hal-01563152 , version 1 (17-07-2017)
hal-01563152 , version 2 (06-11-2018)
hal-01563152 , version 3 (06-11-2019)
Pascal Germain, Amaury Habrard, François Laviolette, Emilie Morvant. PAC-Bayes and Domain Adaptation. 2018. ⟨hal-01563152v2⟩
326 Consultations
547 Téléchargements
