Target Recognition of Software Research about Machine System of Accurately Spraying - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The software is used modularity and qeneric idea, realize target recognition and accurately spraying, it consist of five modules: module of image process, module of identifing the crop from the background of elaphic, module of target recognition and classification of treatment, module of intelligent decision-making and helpness. Image process is made of distortion adjustment,gray strengthen, neighbourhoods average, histogram equalization and median filter; the module of identifing the crop from the background of elaphic is made of division of green strength threshold, division of H hue threshold and segmentation afterwards process and so on; the module of target recognition consist of recognition of fruiter, rice, wheate and target process and area calculating, the module of recognition of fruiter include centre recognition function; the module of intelligent decision-making include information target transmited. The system has fault-tolerant function and automatically judges the input of image or not, automatically detects input of camera and terminal setting, connection situation of singlechip, creating executable file, breaking away from VC++ then direct running. Limiting surface of software system is friendly, simple clear and satisfy the real-time processing the request.
978-3-642-18354-6_5_Chapter.pdf (213.07 Ko) Télécharger le fichier
hal-01563448 , version 1 (17-07-2017)
Paternité
Yan Shi, Chunmei Zhang, Maogang Li, Haibo Yuan. Target Recognition of Software Research about Machine System of Accurately Spraying. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.29-35, ⟨10.1007/978-3-642-18354-6_5⟩. ⟨hal-01563448⟩
70 Consultations
62 Téléchargements
