Study on Model of Risk Assessment of Standard Operation in Rural Power Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Qingji Li
  • Fonction : Auteur
  • PersonId : 1012878
Operation risk is the primary risk to rural power company, and it is also an important part of security risk management. The paper establishes a model to assessed risks of standard operation in rural power network, based on Job Risk Analysis (LEC). The example and application of the model in rural power network security risk management system shows that it can realize the real-time assessment of standard operation risk, the model use is simple and the assessment result is accurate. This study has important reference value to practical application of rural power security risk assessment.
978-3-642-18354-6_52_Chapter.pdf (147.08 Ko) Télécharger le fichier
hal-01563465 , version 1 (17-07-2017)
Paternité
Qingji Li, Tao Yang. Study on Model of Risk Assessment of Standard Operation in Rural Power Network. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.440-444, ⟨10.1007/978-3-642-18354-6_52⟩. ⟨hal-01563465⟩
29 Consultations
227 Téléchargements
