Supply Chain Integration Based on Core Manufacturing Enterprise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
System integration solutions and model of supply chain are proposed based on core manufacturing companies, combining the actual operation of the supply chain process of a motor enterprise. The operation of the supply chain is discussed from the supplier integration, internal integration, and customer integration. The process integration is studied from the logistics integration, information flow integration and capital flow integration. Strategic decision management corresponding to cultural integration, separately discuss from the development strategic integration, concept integration and management integration.
978-3-642-18354-6_3_Chapter.pdf (79.02 Ko) Télécharger le fichier
hal-01563471 , version 1 (17-07-2017)
Paternité
Wenqin Cao, Haiyan Zhu. Supply Chain Integration Based on Core Manufacturing Enterprise. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.14-19, ⟨10.1007/978-3-642-18354-6_3⟩. ⟨hal-01563471⟩
67 Consultations
79 Téléchargements
