Dansk Datamatik Center - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ole N. Oest
  • Fonction : Auteur
  • PersonId : 1013041
Leif Rystrøm
  • Fonction : Auteur
  • PersonId : 1013042
In 1979, a software research and development center was created to demonstrate the power of systematic and formal methods in software development. One of the first and biggest projects at Dansk Datamatik Center (DDC) was to develop an Ada compiler and run-time system. DDC made the first department of Defense (DoD) validated Ada compiler in Europe, and the Ada project was carried on in a subsidiary called DDC–I, Inc. This paper describes the background and start of DDC and some aspects of the formal development method called “Rigorous Approach to Industrial Software Engineering” (RAISE) as well as other DDC activities.
978-3-642-23315-9_39_Chapter.pdf (385.97 Ko) Télécharger le fichier
hal-01564662 , version 1 (19-07-2017)
Paternité
Dines Bjørner, Christian Gram, Ole N. Oest, Leif Rystrøm. Dansk Datamatik Center. 3rd History of Nordic Computing (HiNC), Oct 2010, Stockholm, Sweden. pp.350-359, ⟨10.1007/978-3-642-23315-9_39⟩. ⟨hal-01564662⟩
88 Consultations
138 Téléchargements
