Parameters Turning of the Active-Disturbance Rejection Controller Based on RBF Neural Network - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
(1) , (1)
1
Baifen Liu
  • Function : Author
  • PersonId : 1013088
Ying Gao
  • Function : Author
  • PersonId : 1013089
The Active-disturbance rejection control (ADRC) has the advantage of strong robustness, anti-interference capability, and it does not rely on the accurate math model of controlled plant. But the parameter self-turning of ADRC isn’t as easy as PID controller because there are more parameters to turn in ADRC. In this paper the parameters are self-turning by the Radial Basis Function (RBF) Neural Network. The results of the simulation indicate that the controller has good anti-interference capability and fast response. The robustness of the system is improved.
978-3-642-18369-0_30_Chapter.pdf (174.03 Ko) Télécharger le fichier
Dates and versions
hal-01564845 , version 1 (19-07-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Baifen Liu, Ying Gao. Parameters Turning of the Active-Disturbance Rejection Controller Based on RBF Neural Network. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.260-267, ⟨10.1007/978-3-642-18369-0_30⟩. ⟨hal-01564845⟩
42 View
181 Download
Share
