Test Analysis and Theoretical Calculation on Braking Distance of Automobile with ABS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Braking performance test methods are compared and analyzed. ABS will not work if the speed is too low when the automobile is tested by tester and load testing. Since the braking performance can not be evaluated accurately in this case, the theoretical calculation of braking distance is given in this paper. The calculation result shown the potential of braking performance is mainly on high speed for the automobile with ABS. High-speed road test is designed, and the test results are close to calculation ones, so calculation model is of accuracy. It is less error and better precision than existing calculation way, this method is effective and accurate.
978-3-642-18369-0_62_Chapter.pdf (237.5 Ko) Télécharger le fichier
hal-01564864 , version 1 (19-07-2017)
Paternité
Dongsheng Wu, Jun Li, Xiaoping Shu, Xiaojing Zha, Beili Xu. Test Analysis and Theoretical Calculation on Braking Distance of Automobile with ABS. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.521-527, ⟨10.1007/978-3-642-18369-0_62⟩. ⟨hal-01564864⟩
67 Consultations
200 Téléchargements
