HMM-Based Abnormal Behaviour Detection Using Heterogeneous Sensor Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hadi Aliakbarpour
  • Fonction : Auteur
  • PersonId : 1013279
Kamrad Khoshhal
  • Fonction : Auteur
  • PersonId : 1013280
João Quintas
  • Fonction : Auteur
  • PersonId : 1013281
Kamel Mekhnacha
  • Fonction : Auteur
  • PersonId : 849018
Julien Ros
  • Fonction : Auteur
  • PersonId : 1013282
Maria Andersson
  • Fonction : Auteur
  • PersonId : 1013283
Jorge Dias
  • Fonction : Auteur
  • PersonId : 988853
This paper proposes a HMM-based approach for detecting abnormal situations in some simulated ATM (Automated Teller Machine) scenarios, by using a network of heterogeneous sensors. The applied sensor network comprises of cameras and microphone arrays. The idea is to use such a sensor network in order to detect the normality or abnormality of the scenes in terms of whether a robbery is happening or not. The normal or abnormal event detection is performed in two stages. Firstly, a set of low-level-features (LLFs) is obtained by applying three different classifiers (what are called here as low-level classifiers) in parallel on the input data. The low-level classifiers are namely Laban Movement Analysis (LMA), crowd and audio analysis. Then the obtained LLFs are fed to a concurrent Hidden Markov Model in order to classify the state of the system (what is called here as high-level classification). The attained experimental results validate the applicability and effectiveness of the using heterogeneous sensor network to detect abnormal events in the security applications.
978-3-642-19170-1_30_Chapter.pdf (661.47 Ko) Télécharger le fichier
hal-01566541 , version 1 (21-07-2017)
Paternité
Hadi Aliakbarpour, Kamrad Khoshhal, João Quintas, Kamel Mekhnacha, Julien Ros, et al.. HMM-Based Abnormal Behaviour Detection Using Heterogeneous Sensor Network. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.277-285, ⟨10.1007/978-3-642-19170-1_30⟩. ⟨hal-01566541⟩
107 Consultations
220 Téléchargements
