Optimization of Losses in Permanent Magnet Synchronous Motors for Electric Vehicle Application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this paper is to analyze the influence of some parameters related with the permanent magnet motor control, which are being considered as an attractive alternative for electrical vehicle application where it is important to minimize the losses to increase the vehicle autonomy. In this paper, the attention is focused on the selection of the speed controller parameters and its impact both in mechanical losses as in the corresponding torque-speed trajectories. Moreover, the dependency of the switching frequency over the total losses in the motor-converter device is shown. The analysis determines the optimum value for the switching frequency and the results are compared with commercial servos.
978-3-642-19170-1_55_Chapter.pdf (399.99 Ko) Télécharger le fichier
hal-01566545 , version 1 (21-07-2017)
Paternité
Ana Isabel León-Sánchez, Enrique Romero-Cadaval, María Isabel Milanés-Montero, Javier Gallardo-Lozano. Optimization of Losses in Permanent Magnet Synchronous Motors for Electric Vehicle Application. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.502-509, ⟨10.1007/978-3-642-19170-1_55⟩. ⟨hal-01566545⟩
165 Consultations
455 Téléchargements
