Energy Management System and Controlling Methods for a LDH1250HP Diesel Locomotive Based on Supercapacitors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marius Cătălin Carp
  • Fonction : Auteur
  • PersonId : 1013294
Ana Maria Puşcaş
  • Fonction : Auteur
  • PersonId : 1013295
Paul Nicolae Borza
  • Fonction : Auteur
  • PersonId : 1013296
The present research is focused on developing solutions for increasing the lifetime of the batteries used on diesel locomotive. In order to increase the lifetime of the batteries and to reduce the fuel consumption and the pollutants, an intelligent starting system of the diesel locomotive is proposed. The starting system is composed of supercapacitors, batteries and adequate control system used for controlling the power flow from the storage devices to the internal combustion engine in the starting process. The implementation is described, modeled and simulated and the results of the simulations are compared with the experimental ones.
978-3-642-19170-1_47_Chapter.pdf (602.32 Ko) Télécharger le fichier
hal-01566551 , version 1 (21-07-2017)
Paternité
Marius Cătălin Carp, Ana Maria Puşcaş, Paul Nicolae Borza. Energy Management System and Controlling Methods for a LDH1250HP Diesel Locomotive Based on Supercapacitors. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.429-436, ⟨10.1007/978-3-642-19170-1_47⟩. ⟨hal-01566551⟩
62 Consultations
77 Téléchargements
