Motion Patterns: Signal Interpretation towards the Laban Movement Analysis Semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Luís Santos
  • Fonction : Auteur
  • PersonId : 1013298
Jorge Dias
  • Fonction : Auteur
  • PersonId : 988853
This work studies the performance of different signal features regarding the qualitative meaning of Laban Movement Analysis semantics. Motion modeling is becoming a prominent scientific area, with research towards multiple applications. The theoretical representation of movements is a valuable tool when developing such models. One representation growing particular relevance in the community is Laban Movement Analysis (LMA). LMA is a movement descriptive language which was developed with underlying semantics. Divided in components, its qualities are mostly divided in binomial extreme states. One relevant issue to this problem is the interpretation of signal features into Laban semantics. There are multiple signal processing algorithms for feature generation, each providing different characteristics. We implemented some, covering a range of those measure categories. The results for method comparison are provided in terms of class separability of the LMA space state.
978-3-642-19170-1_36_Chapter.pdf (137.25 Ko) Télécharger le fichier
hal-01566557 , version 1 (21-07-2017)
Paternité
Luís Santos, Jorge Dias. Motion Patterns: Signal Interpretation towards the Laban Movement Analysis Semantics. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.333-340, ⟨10.1007/978-3-642-19170-1_36⟩. ⟨hal-01566557⟩
60 Consultations
87 Téléchargements
