CMOS Fully Differential Feedforward-Regulated Folded Cascode Amplifier - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A fully differential self-biased inverter-based folded cascode amplifier which uses the feedforward-regulated cascode principle is presented. A detailed small-signal analysis covering both the differential-mode and the common-mode paths of the amplifier is provided. Based on these theoretical results a design is given and transistor level simulations validate the theoretical study and also demonstrate the efficiency and usefulness of the proposed amplifier.
978-3-642-19170-1_62_Chapter.pdf (156.63 Ko) Télécharger le fichier
hal-01566584 , version 1 (21-07-2017)
Paternité
Edinei Santin, Michael Figueiredo, João Goes, Luís B. Oliveira. CMOS Fully Differential Feedforward-Regulated Folded Cascode Amplifier. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.565-572, ⟨10.1007/978-3-642-19170-1_62⟩. ⟨hal-01566584⟩
162 Consultations
573 Téléchargements
