Martingale driven BSDEs, PDEs and other related deterministic problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We focus on a class of BSDEs driven by a cadlag martingale and corresponding Markov type BSDE which arise when the randomness of the driver appears through a Markov process. To those BSDEs we associate a deterministic problem which, when the Markov process is a Brownian diffusion, is nothing else but a parabolic type PDE. The solution of the deterministic problem is intended as decoupled mild solution, and it is formulated with the help of a time-inhomogeneous semigroup.
MarkovBSDEs_To_submit_SPAJuly2017.pdf (438.09 Ko) Télécharger le fichier
hal-01566883 , version 1 (21-07-2017)
hal-01566883 , version 2 (26-11-2020)
Adrien Barrasso, Francesco Russo. Martingale driven BSDEs, PDEs and other related deterministic problems. 2017. ⟨hal-01566883v1⟩
Collections
UNIV-PARIS-SACLAY
191 Consultations
141 Téléchargements
