Some Hardware Aspects of the BESM-6 Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
V. I. Smirnov
  • Fonction : Auteur
  • PersonId : 1013557
This paper very shortly describes some hardware solutions of central processor (CPU) of BESM-6. CPU had very deep instruction pipe with an associative buffer for instructions and an associative buffer for data with original protocol. Logical and storage elements used only domestic discrete components. Main logical unit based on differential amplifier with pyramid of rich diode logic and paraphase synchronization. Original construction without printed plate made wire connections very short and gave possibilities for direct access to every contacts and interchanging modules. All these solutions permitted to achieve high clock frequency, reliability and effective maintenance.
978-3-642-22816-2_3_Chapter.pdf (1 Mo) Télécharger le fichier
hal-01568415 , version 1 (25-07-2017)
Paternité
V. I. Smirnov. Some Hardware Aspects of the BESM-6 Design. 1st Soviet and Russian Computing (SoRuCom), Jul 2006, Petrozavodsk, Russia. pp.20-25, ⟨10.1007/978-3-642-22816-2_3⟩. ⟨hal-01568415⟩
45 Consultations
115 Téléchargements
