GINA (Geographical Information Assistant) Fresh Wind in Environmental Mapping
GINA is a comprehensive software system for field workers allowing effective mapping of environment and situation. The GINA makes easier by its design the mapping works in the terrain and protects the collected data. It runs on hardware of Motorola Company which has sturdy design for work in the field and is perfectly adjusted to needs of field workers. By means of GINA System can be realized mapping projects in extravilans that wouldn’t be even possible to do by traditional methods.
Informatique [cs]
