Towards User Requirements for an Information System of the Integrated Rhine Programme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rainer Junker
  • Fonction : Auteur
  • PersonId : 1013721
Ulrike Pfarr
  • Fonction : Auteur
  • PersonId : 1013722
The Integrated Rhine Programme (IRP) is a strategic integrated measurement programme of the German federal state of Baden-Württemberg that aims at an improvement of flood control as well as the preservation and/or the restoration of the Upper Rhine plains. The implementation of the IRP shall be supported by an integrated and sustainable Information System for the IRP (IS-IRP) as an extension of the Environmental Information System of Baden-Württemberg. This paper describes how the analysis and design methodology SERVUS is applied to gather and document the functional and informational user requirements for the IS-IRP. SERVUS denotes a Design Methodology for Information Systems based upon Geospatial Service-oriented Architectures and the Modelling of Use Cases and Capabilities as Resources.
978-3-642-22285-6_70_Chapter.pdf (307.06 Ko) Télécharger le fichier
hal-01569220 , version 1 (26-07-2017)
Paternité
Thomas Usländer, Rainer Junker, Ulrike Pfarr. Towards User Requirements for an Information System of the Integrated Rhine Programme. 9th International Symposium on Environmental Software Systems (ISESS), Jun 2011, Brno, Czech Republic. pp.651-656, ⟨10.1007/978-3-642-22285-6_70⟩. ⟨hal-01569220⟩
84 Consultations
84 Téléchargements
