Crosstalk Fault Tolerant NoC: Design and Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
The innovations on integrated circuit fabrics are continuously reducing components size, which increases the logic density of systems-on-chip (SoC), but also affect the reliability of these components. Chip-level global buses are especially subject to crosstalk faults, which can lead to increased delay and glitches. This paper evaluates different crosstalk fault tolerant approaches for Networks-on-chip (NoCs) links such that the network can maintain the original network performance even in the presence of errors. Three different approaches are presented and evaluated in terms of area overhead, packet latency, power consumption, and residual fault coverage. Results demonstrate that the use of CRC coding at each link is preferred when minimal area and power overhead are the main goals. However, each one of the methods presented here has its own advantages and can be applied depending on the application.
978-3-642-23120-9_5_Chapter.pdf (293 Ko) Télécharger le fichier
Dates and versions
hal-01569362 , version 1 (26-07-2017)
Attribution
Identifiers
Cite
Alzemiro H. Lucas, Alexandre M. Amory, Fernando Gehm Moraes. Crosstalk Fault Tolerant NoC: Design and Evaluation. 17th International Conference on Very Large Scale Integration (VLSISOC), Oct 2009, Florianópolis, Brazil. pp.81-93, ⟨10.1007/978-3-642-23120-9_5⟩. ⟨hal-01569362⟩
73 View
109 Download
Share
