E3value to BPMN Model Transformation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hassan Fatemi
  • Fonction : Auteur
  • PersonId : 1013845
Marten Van Sinderen
  • Fonction : Auteur
  • PersonId : 998714
Business value and coordination process perspectives need to be taken into consideration while modeling business collaborations. The need for these two models stems from the importance of separating the how from the what concerns. A business value model shows what is offered by whom to whom while a coordination process model shows how these offerings are fulfilled operationally. This case study addresses the model transformation between e3value and BPMN, commonly used for modeling business collaborations from value and coordination perspectives respectively.
978-3-642-23330-2_37_Chapter.pdf (589.67 Ko) Télécharger le fichier
hal-01569970 , version 1 (28-07-2017)
Paternité
Hassan Fatemi, Marten Van Sinderen, Roel Wieringa. E3value to BPMN Model Transformation. 12th Working Conference on Virtual Enterprises (PROVE), Oct 2011, São Paulo, Brazil. pp.333-340, ⟨10.1007/978-3-642-23330-2_37⟩. ⟨hal-01569970⟩
166 Consultations
138 Téléchargements
