Towards a Theory of Collaborative Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Donald Neumann
  • Fonction : Auteur
  • PersonId : 1007870
Luis Santa-Eulalia
  • Fonction : Auteur
  • PersonId : 1013860
Erich Zahn
  • Fonction : Auteur
  • PersonId : 1013861
High failure rates often observed in practice suggest that collaborative relationships are still not well understood. In this paper we investigate the nature of these relationships from second-order Cybernetics and Social Systems Theory perspectives. Thereby we develop a novel theoretical framework, the Collaborative System, which explains: 1. the organizational function of collaboration; 2. the system’s elementary operation; 3. its coupling mechanism; 4. the system autonomy and; 5. its ‘value’ creation mechanism. The proposed framework is innovative and has far reaching consequences for the understanding of different forms of collaborative relationships. Nevertheless, it raises a whole new set of questions yet to be explored.
978-3-642-23330-2_34_Chapter.pdf (63.79 Ko) Télécharger le fichier
hal-01569978 , version 1 (28-07-2017)
Paternité
Donald Neumann, Luis Santa-Eulalia, Erich Zahn. Towards a Theory of Collaborative Systems. 12th Working Conference on Virtual Enterprises (PROVE), Oct 2011, São Paulo, Brazil. pp.306-313, ⟨10.1007/978-3-642-23330-2_34⟩. ⟨hal-01569978⟩
65 Consultations
192 Téléchargements
