A Neural Network Tool for the Interpolation of foF2 Data in the Presence of Sporadic E Layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Haris Haralambous
  • Fonction : Auteur
  • PersonId : 1000598
Harris Papadopoulos
  • Fonction : Auteur
  • PersonId : 992370
This paper presents the application of Neural Networks for the interpolation of (critical frequency) foF2 data over Cyprus in the presence of sporadic E layer which is a frequent phenomenon during summer months causing inevitable gaps in the foF2 data series. This ionospheric characteristic (foF2) constitutes the most important parameter in HF (High Frequency) communications since it is used to derive the optimum operating frequency in HF links and therefore interpolating missing data is very important in preserving the data series which is used in long-term prediction procedures and models.
978-3-642-23957-1_35_Chapter.pdf (550.22 Ko) Télécharger le fichier
hal-01571326 , version 1 (02-08-2017)
Paternité
Haris Haralambous, Antonis Ioannou, Harris Papadopoulos. A Neural Network Tool for the Interpolation of foF2 Data in the Presence of Sporadic E Layer. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.306-314, ⟨10.1007/978-3-642-23957-1_35⟩. ⟨hal-01571326⟩
76 Consultations
139 Téléchargements
