An Artificial Intelligence-Based Environment Quality Analysis System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mihaela Oprea
  • Fonction : Auteur
  • PersonId : 1008260
Lazaros Iliadis
  • Fonction : Auteur
  • PersonId : 992393
The paper describes an environment quality analysis system based on a combination of some artificial intelligence techniques, artificial neural networks and rule-based expert systems. Two case studies of the system use are discussed: air pollution analysis and flood forecasting with their impact on the environment and on the population health. The system can be used by an environmental decision support system in order to manage various environmental critical situations (such as floods and environmental pollution), and to inform the population about the state of the environment quality.
978-3-642-23957-1_55_Chapter.pdf (177.49 Ko) Télécharger le fichier
hal-01571336 , version 1 (02-08-2017)
Paternité
Mihaela Oprea, Lazaros Iliadis. An Artificial Intelligence-Based Environment Quality Analysis System. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.499-508, ⟨10.1007/978-3-642-23957-1_55⟩. ⟨hal-01571336⟩
65 Consultations
553 Téléchargements
